2 members (Materman, 1 invisible),
111
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Searched with no results. Can anyone tell me the approximate weight of a 1941 GMC cc-303 which is a 2-ton I believe. It has a partial flat bed, 228 engine. Rough guess is fine. Thanks, Dave
1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Rough guess: 6,000 lb, perhaps slightly less.
Grigg | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | CC-303, is a 300 series, which would be a 1 1/2 ton. A '47-'55 model 303-24 300 series 1 1/2 ton cab, & chassis, has an approximate weight of 4545lb.s Same truck with platform body is, 5275lb.s. So i'm going to guess the earlier trucks, would be a tad lighter. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Have you guys seen this picture? Do you know what the extra lever is for? I've only seen pictures of the truck so far. Thahttp://good-times.webshots.com/photo/2539518610101947398oXhRoqnks for the weight guestamate. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think that lever is for the mechanically shifted two speed rear axle. But I could be wrong, Grigg
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | That's my guess but I won't know for sure until I can see it in person. Thanks, Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Looks like it could also be to operate a pump or added equipment. | | | | | Joined: Dec 2006 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 66 | Dave, It appears to be the same lever I have on my 46. It shifts an "extra" transmission/gearbox that you apparently also have. A fellow 'bolter told me they were called a "brownie" ??? Got me. He didn't know the reason for them (nor do I), but I can tell you this much, when you shift it into what I'll call low range, any box turtle can outrun you! With your power going through an additional gearbox, you will have some extra whining and groaning. It is much more noisy than my 54. But I find it an addtional piece of interesting truck history. Hope that helps. Scott | | |
