9 members (farmallb, JW51, Barney1951, klhansen, Bill Hanlon, Otto Skorzeny, 1955 1 Series, sron48, 1 invisible),
87
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,487 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 15 New Guy | | New Guy Joined: Mar 2008 Posts: 15 | I am new to stovebolt and have just puchased a stock 1954 3100 5 window pickup.I have searched and seen the posts on rear ends and open drive lines, etc. What I want to know is will the later model chevy 3spds. work on my 51 3100? I want to keep the three on the tree. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | There are a number of 3 speeds that will fit your truck if you are converting to an open driveline. The most common is from 55 through 60. You can also use an overdrive from those years. Later models with the short tail shaft will fit also. Full syncro Saganaw 3 speeds came out in 68 and can also be used. You will have to work out some shifter and driveshaft issues but there are many options. I understand that a kit is available to use a saganaw 3 speed with the torque tube. There are others that can provide that info. Fred
