1 members (Rnl364), 59 guests, and 2 robots.
Topics128,064
Posts1,055,859
Members48,428
#392773 03/25/2008 2:44 AM
I am looking for a heavy duty primer to put on the floor in my '61. I have the floor stripped to metal, rust and old paint. I need to take a wire wheel to it and clean it up before I primer it.
I am curious what you guys think about primers.
Do I need brush on? I like the idea of brush on cause I am not gonna have overspray everywhere. I am not doing a full overhaul so pedals, stering wheel, etc. are still in the cab.
There was a post a while back about some sort of farm equipment paint that is realy strong.
Anyways, mostly I just need some help brainstorming.
Fire Away!
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
i primed my after blasting. Next I will be painting on bed liner. That should help seal and insulate. Then the Dynamat for temp and more sound deadening.
~Jim
Por 15 would work well, but you would want to paint the transmisson access cover seperatly. If you were to paint it assembled it would be almost impossible to remove the screws and cover.
1949 Chevy 6400
1931 Chevy Firetruck
not sure what your looking for but when i had mine blasted about ten yrs ago,i brushed on rustoleum primer then a couple coats of their gloss black.then the project stalled for 8or9yrs and sat outside unprotected,it held up very well.this was the outside bottom.i would do it again...............dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Yeah, I actually took the tranny cover off just for inspection purposes. My transmission is freakin' huge!!! No wonder the thing drives like a tractor!
I was thinking about a rustoleum product. I have had good luck wth them in the past. I wasn't sure if it was durable enough for a floor application though.
My Machine
Kyle,
After sandblasting my cab the underneath was pitted real bad. I brushed a couple of coats of BPS paint(Tractor Supply)to fill in pits and them painted. It looks OK. I don't know if this is the best in cab primer but brushing the paint on your floor will save the time masking and will slow the rusting process. Good luck and have fun.
Dan
Apprentice
Apprentice
Epoxy prime it
Originally Posted by mkabwe
Epoxy prime it
I agree that is the best way. if not rustoleum will hold up
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
