1 members (baldeagle),
40
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39265 03/07/2004 5:27 PM | Joined: Feb 2004 Posts: 18 Junior Member | | Junior Member Joined: Feb 2004 Posts: 18 | Since (with the help of others) I have determined I have a 261, I need to find some info on this engine. On the 6066 gmc webpage it has info for all inlines but this one. I would like to fond out torque and hp ratings to see if this is the engine I want. Does this engine compare to the 292?? Does it have the low end torque and is there room for improvement?
Also the book: Chevrolet Inline Six Cylinder Power Manual has been highly recommended but it doesn't look like it covers 261's. Does anyone have input on this??
Thanks az | | |
#39266 03/07/2004 8:06 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Santucci's book is mostly for the L22 series (194/215/230/250/292) engines. If you look around on eBay, there is a '50s book (reprint) on tuning old Chevy and GMC engines that shows up from time to time. | | |
#39267 03/07/2004 8:20 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | 261 advertised HP is 150 at 4000 rpm,torque,235 lbs ft at 2000 rpm. The one and only reliable 50's dyno test of a stock 261 showed 114 actual HP at 3500 and the torque was 200 at 2000 rpm.For low speed engines like these, all they have is low speed torque. I have 2 good running 261's in Pu's one is more or less stock,the other has a mild cam,cast iron headers and a 4 bbl.The modified engine pulls as good as the stocker down low and is way better over 3000 rpm. I would say stock 292 makes more pulling power, and yes, Leo's book only covers the later 6's.You can look in the old 50's 235 tuning books or buy a May 1955 Hot Rod magazine on Ebay, the book has the only good 261 modifications and dyno tests available. | | |
#39268 03/09/2004 7:51 PM | Joined: Feb 2004 Posts: 18 Junior Member | | Junior Member Joined: Feb 2004 Posts: 18 | So the may 1955 hot rod magazine is an issue worth picking up?
Are this issue and the "How to Hop Up Chevrolet & GMC Engines" book the best resources for the 261?? \ Thanks az | | |
#39269 03/09/2004 10:02 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Or you could join Inliners Int. and as a member write one of our technical advisors. The old hop up books are ok but a few things have changed in the 50 plus years since those went to print. The 12 Port News has had many articles on building the 261s, some of those are still available in the back issue stash. Best of luck. | | |
#39270 03/09/2004 10:21 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Inliners has a new "formula" out for the 261 that uses commonly available Cadillac pistons and rods on an offset ground 261 crank to make a higher revving more strokey engine with lighter rotating parts to make big torque. It's not on their website, though, you have to buy the backissue newsletter. It's supposed to be quite a package.
#39271 03/10/2004 12:36 AM | Joined: Oct 2003 Posts: 62 Member | | Member Joined: Oct 2003 Posts: 62 | thanks for the 261 info. i got mine by accident. rebuilt it 30 over,cast pistons,hydrolic vavles, a small,new holly 4bb,clifford intake,mallory elect ignition. everything balanced. just got it going in the ol'40 ,stock, truck. I'm afraid if that 4bb kicks in the motor'll shoot right out the grill. Boy,does this thing run ! | | |
#39272 03/10/2004 7:39 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | They are nice and torquey. I have been hauling a bunch of firewood in my truck lately and it doesn't even break a sweat. Mine is stock.
