5 members (1955 1 Series, Oswald, Woodcmiami, Nick in Manitou, MRMEROTH11), 144 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
Apprentice
Apprentice
Hello,
what would be the easiest way to convert my 1951 chevy 1 ton to dual wheels?
Ryan
If you lived near Fort Worth I'd say the easiest way would be to swap me your axle. I'm converting my '51 1 ton flatbed to a pickup bed, which means I'm going to have to also swap the dually axle with a 1 ton single.
Were you wanting the keep the same ratio on the new one? I believe 1 ton duallys came with a 5.14.
Dave
If you want to run dual wheels on the front you need dual type front hubs. The original wheels would be hub-piloted 18 inchers.
I have a '54 GMC 1-ton dually and can look at it to answer questions for you if you like.
Apprentice
Apprentice
I want to run the same gears as my truck came from the factory with 5.14 gears, I would like to swap out to the proper parts for my year,
my father drives semi and in in texas alot so maybe we could work out a deal.
I need to find front and rear axles and 6 rims.
Ryan
