7 members (Hotrod Lincoln, bobfake, GRNHydra, tclederman, Woodcmiami, Otto Skorzeny, 2-Ton),
43
Mod | | | Forums66 Topics128,091 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | I scored a 2004 6.6l Duramax Diesel engine for my truck today. I got it for $ 3000.00. It is supposed to have only 20,000 miles on it. It looks pretty clean, so I may believe that number. Pics can be seen at http://community.webshots.com/album/562816192hotBxOLane | | | | | Joined: Jun 2007 Posts: 137 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 137 | Looks like you are moving on along. You really utilized your storage space very well stacking your parts like that. That is going to be a cool truck to drive! | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Duramax powered. Sounds cool. I hope those springs you have on your ride hold up. Dmax is heavy and lots 'o' torque. I toyed with the idea of a 6.2 or 6.5 due to the fact they use big block motor mounts and virtually any chevy trans will bolt to them. I hanged my mind though, I figured if I was going to drive an oil leaker, I'd stick with what I got. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I understand you have to have the complete computer system to make it work. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | All,
Well, the original truck was a one-ton, so I'm hoping it'll carry the weight. I've already reinforced the frame just for good measure.
As far as computer system, I've been talking to a company that converts the duramax for marine use. They tell me they will be marketing a plug-in system for the duramax that will only require a constant 12v source, a switched 12v source and a ground wire. Their system will be available in either 650 or 850 HP versions (I think I'll get the 850 HP version!). This package was unveiled at SEMA last year and should be available fairly soon (I was told 1st quarter of '08).
I'm hoping to be able to surprise a lot of people once I get this thing on the road.
Lane
| | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Lane!
One ton 4x4 Diesel! AWESOME!
I was imagining doing the same on one of my TF's since I have the axles already.
What are your plans for the steering box?
| | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | Hey Zeke, If you go to http://good-times.webshots.com/photo/2217902440098190200FmzEUc youll see what I accomplished today! I picked up a Saginaw power steering box off of a '82 Chev 1/2 ton and mounted it according to the directions at http://www.classicperform.com/power2.htmIt wasn't too bad, only took me a couple of hours. I had to fab up some spacers and the 'triangular bracket' that they supply in the kit. If you're ever up this far north, drop in and I'll give you the nickle tour! Lane | | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Hey Lane,
Nice work!
It's really cool that you can use the Chevy steering box. I didn't know it could be done. I heard of folks using a Toyota box and that didn't sit well with me.
BTW, is that a hydraulic brake booster you've mocked up there?
Thanks for the invite. I'll see what I can do.
Zeke | | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | Zeke,
Yep, I have to use the hydroboost as a diesel engine will not produce any vacumn to power anything unless you add a vacumn pump (I guess I'll also have to change to electric wipers!).
I got the booster and master cylinder mounted yesterday.
Invite is always open to any 'bolter that shows up!
Lane | | |
