| | | Forums66 Topics128,195 Posts1,057,377 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 23 New Guy | | New Guy Joined: Feb 2008 Posts: 23 | In appreation I would like to hear some comments on installing filler strips in rubber around glass side, and rear windows. Is the tool absolutely a must when installing, and is temp. a factor. It seems so darn tight even using soap water. Are there any tricks. Many thanks....Sepp
Plattelnjpichler
| | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Sepp, I installed mine without the tool. It was slow going. I used a paint can key because it was blunt enough to not damamge the strip.
It can be done...If I had to do it again I might buy the tool unless others say it didn't add much to the ease. I also don't have a 5 window. Just one rear window to deal with.
I had to tape the gasket to the window all the way around on both sides to keep it form flopping off.
Rich
| | | | | Joined: Feb 2008 Posts: 23 New Guy | | New Guy Joined: Feb 2008 Posts: 23 | Thanks, I'm going to try putting rubber around rear window now. Which I did not before. (rubber in frame befor) Brothers has a sale now on locking strip install tool ($9.95) I think I'll buy it. Thanks for your help....Sepp
Plattelnjpichler
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Sepp, I didnt have much luck with the tool, it wanted to bind on the locking strip and I installed the chrome locking strip, the tool wanted to dent it an was kinda a hassle, I had the best luck with a small flat tip screw driver & a set of those dental type pics, the set I have has several curved tips on em they worked great for gettin in the strip and working the lock in,now I did mine with my brothers help, we took our time not to scratch the new paint. We did it as follows, my brother stayed a few inches ahead of me applying pressure and keeping the lock strip straight while I worked it in, I have an after market rear slider wich made for a pretty tight install if it was flat glass it surely would have been easier. and took us abought an hr to put in all 3 back windows. Temp was around 70 degrees. Tim P.S. a little bit of WD40 sprayed in the locking strip track helps tremendously! | | | | | Joined: Feb 2008 Posts: 23 New Guy | | New Guy Joined: Feb 2008 Posts: 23 | Thanks for your info...I'm sure it will help...Keep on trucken...Sepp
Plattelnjpichler
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Like rust Bucket 53, I used a paint can opener. I found that waterless hand cleaner worked a lot better than soapy water.
I really struggled with it, though, and I ordered the tool, which came just after I finished by using the paint can opener. | | |
