6 members (Hambone, Gdads51, dt235sd, papas52, Bruce 1954-4100, tclederman), 129 guests, and 2 robots.
Topics128,111
Posts1,056,258
Members48,437
#39064 03/28/2005 3:13 PM
I put an ad in a local paper for an S-10 T5 to go in my '41. I had a call this morning from a man who says he has 2 NV-3500 5 spd's from a '94 S-10. He says they are the same as the T5. I have only did research on the T5 and don't have a clue what an NV-3500 is. Will this transmission bolt up the same as a T5? Is it as good a candidate for the swap into my '41 using the 235 I have? The price is good enough $100 for both. One works good and the other he says 2nd gear is bad. I don't won't to buy the wrong thing and get stuck. Thanks for your replies.
Mike
#39065 03/28/2005 4:53 PM
"MONGO"
"MONGO"
I don't think you'll have any luck with it, it's called a New Venture and it has a integral bell housing. It looks very different than the T5.
http://www.motivegear.com/tech_info/tranny_guide/tranny_guide.html
Although, looking further down that page the NV3550 looks interesting. Looks like the shifter may be mounted too far back for it though. Also since it doesn't look like it was every used in the 2.8 chevy's it may not bolt up.
Mongo
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
#39066 03/28/2005 5:54 PM
The New Venture-built NV 3550 has, I think, a standard GM pattern on the front of that integral bellhousing.
1954 GMC De Luxe COE
#39067 03/28/2005 6:19 PM
Thanks guys, I'll keep looking for a T5.
Mike
#39068 03/28/2005 6:41 PM
All S10's with the 4.3,91 and up ,have the NV3500 trans.The larger trucks with V-8's usually have the NV4500,but the 88-92 or so big trucks has a Getrag 5 speed,troublesome at times.
The NV's have an intergal clutch housing as mentioned,if you have the time ,tools and skill,the clutch housing can be machined away and an adapter made to work on the 235,maybe.
At any rate, NV tranny replacement parts are expensive and they require some special tools for disassembly.Too bad, it's a far more robust trans than the T-5
