1 members (GMCJammer51), 117 guests, and 4 robots.
Topics128,186
Posts1,057,324
Members48,469
I have what either looks like a factory bump or a very well hammered bump in my cab floor, centered side to side and just forward of the transmission pan where it slopes upward. It looks like it might be for clearance for the foot stomp starter mechanism but I'm working on repairing the cab and I can't tell. Does anybody else have a bump there? Its slightly smaller in diameter than a golf ball and hemispherical.
Paint & Body Shop moderator
I had one like that on my big toe. blush
I got one on each little toe from Steel Toe boots we have to wear now ..in SAFETY'S SAKE.
Now to be serious sorry cant help my floor is Totally flat ..1/8" steel plate welded in over my floor & aoutomatic trans.
1952 Chevy Shortbed
Photos in Photobucket
Yes, about an inch in diameter bumped out about a 1/4" or so and at about 270° and 4" from the foot stomp. It's for clearance of the bolt or screw that hold the cover on the inspection hole. I've never figured out what you would be inspecting up there on the top of the bellhousing under the fire wall. The only way you would ever get into it is when the engine is pulled out.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks, Denny, that's exactly it. I completely forgot about that little cover. That cover allows you to get at the freeze plug on the back of a GMC engine without removing the bellhousing but since you have to take the engine out anyway I'm not sure how much good it really does, except to give your hand a sharp edge to scrape on when you are pulling the bolts.
Well I think you'd be hard pressed to get at the freeze plug with the transmissinon, clutch disc, pressure plate and flywheel in the way.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Moderated by  ndkid275, Phak1
