3 members (Guitplayer, Danielbolt, Hotrod Lincoln), 79 guests, and 1 robot.
Topics128,154
Posts1,056,838
Members48,456
#386210 03/10/2008 11:42 AM
Oldog in Md.
Unregistered
Oldog in Md.
Unregistered
I am going to replace floor pans and rockers on my 66 Chevy truck
Rust through is on outer left and right at rocker
my question is .... through the hole I see what looks like a cross member about a foot long and guess I should replace that piece also .. What is it called ? I would like to have part in hand before starting . Should I have other parts as well ? Any advice helpfull
Dan
Dan ,
If ya search a bit you will find that ya should add some xtra support to your cab before cuttin out as much as you are plannin ..some x-braces will be needed to keep it all in line ..after that ...IM sure the EXPERTS will chime in soon on the particulars .
WELCOME TO THE BOLT !
1952 Chevy Shortbed
Photos in Photobucket
Oldog in Md.
Unregistered
Oldog in Md.
Unregistered
Thanks SW. , Advice well takin ...
I am learning as I go , I think the supports are called Front cab floor supports.... However ther seems to be 2 sizes listed in the catalog...
1 is 4 3/4"W x 14 1/2"L and the other is 7 1/4"W x 14 1/8"l
is this based on year and which one would a 1966 take ?
Dan
Apprentice
Apprentice
LMC Truck lists Your Front cab support as #38-7949 original equipment for $16.95 ea. and the Rear cab support as #38-7954 for the left side and #38-7955 as the right side.each are $16.95
Apprentice
Apprentice
I am replacing my cab supports also on My 65 fleetside.However I am having trouble removing the bolt's from the front ones.I have the nut on the underside removed and the bolt turns freely from the cab floor but the bolt won't come out,anybody know why?I even put a floor jack on the bottom of the bolt to apply pressure on it while wrenching it but that did nothing.Help please
Oldog in Md.
Unregistered
Oldog in Md.
Unregistered
Thanks for the part # 's I am ordering as wespeak !
Thanks again
Dan in Maryland
Is the bolt you are trying to remove through the floor board and front cab support into the frame? If so, once the nut is removed from the bottom, the bolt is free to pull out. You may need to use a drift punch or air chisel from the underside to coax it out, due to rust and corrosion.
When replacing the front and rear cab supports, get the full replacements, not the cab supports that fit over the existing. If you slip new ones over the old, you are compounding the problem that created the rust in the first place. Also, when replacing the cab mounts, jack up each corner of the cab and insert a wood spacer that holds the cab approximately 1" about its actual resting height, in order to have room to manuever. After the cab supports are replaced, insert new cab mounting hardware and rubber/polyurethane spacers and remove the temporary wood blocks. Check cab alignment and securely tighten new cab mounting bolts.
Good luck with your project and I hope this information is helpful.
Apprentice
Apprentice
Thanks for the info Shop Shark, By the way I wouldn't use the slip on type for reasons You cited.
