4 members (Otto Skorzeny, Deegs53, tclederman, 1 invisible), 193 guests, and 5 robots.
Topics128,078
Posts1,056,055
Members48,433
#389681 03/18/2008 5:10 PM
Apprentice
Apprentice
' Offline
Can anyone tell me if there is a replacement pin / bolt for the '54 Chevy vent window? The one that is attached to the vent window frame and extends down with the tension spring attathed.
Joe
'54joe #389688 03/18/2008 5:17 PM
I think that threaded-stud/pin/bolt is welded on. Do you want to know the dimensions of the stud?
Apprentice
Apprentice
' Offline
Yes PLEASE!!
Joe
'54joe #389865 03/19/2008 12:10 AM
That stud has flats on both sides for special washers... you might try asking in the parts wanted forum if anyone has a pranged window they want to get rid of and just have the stud welded on.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #395614 03/31/2008 1:25 AM
I checked out my doors for '54joe but I am not able to make good measurements with the vent in the door.
If anyone has a vent out of a door, would you mind measuring and posting the following information for Joe?
Regarding the vent window-frame stud/bolt/pivot-pin:
1. overall length of the threaded stud on the bottom of the vent window-frame (the window pivots on this bolt)
2. length from window frame to first flat shoulder cut
3. diameter and thread size of the threaded stud
On behalf of Joe, Thanks,
Tim
AAAAAH POOP!....I had my passenger side out & apart till this mornin an I put it together and riveted it, here is the best measurements i could get.
the stud is 5/16" standard thread.
From the edge of the frame to the shoulder of the flat is .205
Approx. .035 ground off each side of the stud..it measures .220 thick with the flats
Overall length of the stud is 1.905,I would guess that 1/16" is in the frame before welding making the total length of the stud 2"
Tim
1952 Chevy Shortbed
Photos in Photobucket
