0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 28 Apprentice | | Apprentice Joined: May 2005 Posts: 28 | Can anyone tell me if there is a replacement pin / bolt for the '54 Chevy vent window? The one that is attached to the vent window frame and extends down with the tension spring attathed. Thanks, Joe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think that threaded-stud/pin/bolt is welded on. Do you want to know the dimensions of the stud? | | | | | Joined: May 2005 Posts: 28 Apprentice | | Apprentice Joined: May 2005 Posts: 28 | | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | That stud has flats on both sides for special washers... you might try asking in the parts wanted forum if anyone has a pranged window they want to get rid of and just have the stud welded on. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I checked out my doors for '54joe but I am not able to make good measurements with the vent in the door.
If anyone has a vent out of a door, would you mind measuring and posting the following information for Joe?
Regarding the vent window-frame stud/bolt/pivot-pin:
1. overall length of the threaded stud on the bottom of the vent window-frame (the window pivots on this bolt)
2. length from window frame to first flat shoulder cut
3. diameter and thread size of the threaded stud
On behalf of Joe, Thanks,
Tim | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | AAAAAH POOP!....I had my passenger side out & apart till this mornin an I put it together and riveted it, here is the best measurements i could get. the stud is 5/16" standard thread. From the edge of the frame to the shoulder of the flat is .205 Approx. .035 ground off each side of the stud..it measures .220 thick with the flats Overall length of the stud is 1.905,I would guess that 1/16" is in the frame before welding making the total length of the stud 2" Tim
