| | | Forums66 Topics128,117 Posts1,056,296 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | I welded in a good size patch on my bed side and I must have got it to hot. Now I have a spot that's warped. What's the best way to shink the metal back in to shape? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | Thanks Tiny for the info. I will give it a try. | | | | | Joined: Sep 2007 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 154 | reheat it with the tourch. not real hot just enough so that when you hit it with a really wet water rag it will shrink. do about as many times as needed untill it's back in shape.
I am not sure if this can be over done. I have done it in the past but quite when I though I was close.
I also have cut it with a cutting wheel to reelieve the excess and then when finished wire welded the damage back up and did the necessary body work, filling & sanding. | | |
