4 members (TUTS 59, Shof, Ponchogl, Jon G), 172 guests, and 3 robots.
Topics128,094
Posts1,056,157
Members48,436
#388425 03/15/2008 8:23 PM
I welded in a good size patch on my bed side and I must have got it to hot. Now I have a spot that's warped. What's the best way to shink the metal back in to shape?
Ex Hall Monitor
Ex Hall Monitor
Thanks Tiny for the info. I will give it a try.
reheat it with the tourch. not real hot just enough so that when you hit it with a really wet water rag it will shrink. do about as many times as needed untill it's back in shape.
I am not sure if this can be over done. I have done it in the past but quite when I though I was close.
I also have cut it with a cutting wheel to reelieve the excess and then when finished wire welded the damage back up and did the necessary body work, filling & sanding.
