| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 52 | As I am starting to put my '49 back together I noticed that on the drivers side there is a brace that mounts to the cab and frame via nut and bolt. This brace has threaded inserts that helps retain the inner fender well. There is none for the passenger side though and when I got to thinking I remembered that the when taking the fenders off, the passenger side was shimmed up the ying yang. My question is whether or not the passenger inner fender well is supposed to be mounted by a similar brace to that of the drivers side. I have check out some cataloges I have but they do not seem to either side available for sale. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | To the best of my knowledge there should be one on both inner fenders. Dimensions are in the Shop Manual. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The passenger side inner fender attaches in a different way than does the driver's side inner fender. Both bolt through the floor but on the passenger side there are captive nuts on the inner fender well. On the driver's side, there is a pedal-assembly bracket that has captive nuts in it.
If you want pictures posted, let me know. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Sorry, I thought he was referring to the threaded rods that go from the firewall to the inner fender. My bad.
tc has it right. | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | i was wondering about the same thing a few months ago when i was bolting up the inner fender wells. I asked to see if anyone had one laying around in the parts wanted section, and i wasn't getting any replies and a few was confused on what i was looking for. I looked through catalogs and such and couldn't find anything, the driverside mount is avaliable in catalogs but not the passengerside. I then finally realized that there was no mount for the passenger side when i went to look at another truck and seen that it was just bolted to the cab. | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Tclederman is right ,they are opposite, on the one side the inner fender bolts to the cab and on the other side the cab bolts to the inner fender. Then, only one side has that bracket. Lothar | | | | | Joined: Jul 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 52 | My passenger side inner fender had no captive nuts. It just had square holes I assumed to be for carriage bolts. Between the cab and inner fender were about 4 thick shims for each bolt. Again with the assumptions, I thought that these shims were in lou of the proper bracket which I thought to resemble that of the drivers side. I knew something was up cause with no captive nuts assembly requires a helper monkey to hold a wrench outside while you turn a ratchet from the inside. A pic of just what is supposed to be going on would be great. I am going to have it on and off quite a lot as a reference for remaking the front lower cab sheet metals. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Tclederman is right ,they are opposite, on the one side the inner fender bolts to the cab and on the other side the cab bolts to the inner fender. Then, only one side has that bracket. Lothar This statement has me scratching my head!
~Jim
| | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | can you say dementia?I meant the bolts on the passenger side go from the inside of the cab through the holes in the firewall and into the threaded inserted nuts in the inner fender. The inner fender has nuts inserted in the fender well.There is no bracket on the pass side of the vehicle like on the driver side. Lothar
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | KillerKnight is correct, except the holes are actually in the toe board not the firewall. | | |
