2 members (MickeyP, KingG),
60
0
Mod | | | Forums66 Topics128,007 Posts1,055,281 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38872 10/31/2003 8:35 PM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | I was looking at a 61 or 62 Pontaic today with a 6 cy. motor...I noticed that the mounts were on each side at the center of the engine.. Is this a 235 ?
1946 chevy 1/2 ton panel 1937 ford coupe | | |
#38873 10/31/2003 11:26 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It could be a 261 if it is in a Canadian Pontiac. You will have to look at the casting numbers, but grab it if it is, they are great motors. The '58-62 US 261's have 1/2" NPT oil filter fittings but I don't think the Canadian ones do. Look for "Captains Bars" above the starter, too.
#38874 11/01/2003 1:05 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Yes, the Canadian Pontiacs had a 261 and they were a great motor. More than that, because they are so popular, there are many new upgrade goodies available.
I think JD was wondering about how the mounts would work out, right ? | | |
#38875 11/01/2003 3:09 PM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | truckernix..On my 53 chevy truck there is one mount at the front and one under the rear (I guess you say under the transmission)..I want to replace the motor in my 46 chevy truck and I was told any motor from 47-62 (235) would bolt right in. But this pontiac motor looks different the motor mounts are located on each side..What kind of probablem will I have to put this in my 46
#38876 11/02/2003 4:28 AM | Joined: Oct 2003 Posts: 62 Member | | Member Joined: Oct 2003 Posts: 62 | hay jdhoward, I was told any stovebolt 6 would mount into my 40' half ton. I got a 62' 261. It did(except for the "fan"thing. jim | | |
#38877 11/02/2003 11:18 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | JD, someone on here will give you the details but, there is virtually no mounting difference that I know of between the 235 and the 261. | | |
#38878 11/03/2003 2:54 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I have a USA spec '62 261. It fits in place of the 216 but I ended up using an electric fan because I did not want to fight clearance issues. The fan sits low on the block instead of up high like pre-'55 motors. I shortened the water pump and used a FOMOCO pulley that bolted right on. That has plenty of clearance to the radiator now, but the stock fan was sitting below the bottom half of the radiator so I run a 2000 cfm electric pusher fan with a thermostatic switch and it works great.
The only other two problems I ran into were the oil filter lines and the belcrank for the throttle linkage. The stock USA 261 has a full flow oil filter mounted to the rear part of the intake manifold, and it hits the steering linkage. I moved mine to mount to the front of the intake and got new oil filter lines (1/2" NPT). This takes the big cannister filter like the early V8s do, not the beehive type. All the oil flows through it.
The throttle linkage requires some bending and shortening of the stock pedal rod. After some trial and error I made it work perfectly. I made a new rod from the bell crank to the carb with some threaded rod and ball joint ends from the hardware store. The ball joint ends are just like miniature tie rod ends and are the best thing since sliced bread. They make the action smooth and tight.
Oh, and if you want to use the bourdon tube temperature gauge, you need a brass adaptor for some heads. Mine needed it. A 1/2" NPT male to 3/8" gas flare female did the trick.
