1 members (Hotrod Lincoln), 88 guests, and 5 robots.
Topics128,014
Posts1,055,325
Members48,419
#38872 10/31/2003 8:35 PM
I was looking at a 61 or 62 Pontaic today with
a 6 cy. motor...I noticed that the mounts
were on each side at the center of the engine..
Is this a 235 ?
1946 chevy 1/2 ton panel
1937 ford coupe
#38873 10/31/2003 11:26 PM
It could be a 261 if it is in a Canadian Pontiac. You will have to look at the casting numbers, but grab it if it is, they are great motors. The '58-62 US 261's have 1/2" NPT oil filter fittings but I don't think the Canadian ones do. Look for "Captains Bars" above the starter, too.
Paint & Body Shop moderator
#38874 11/01/2003 1:05 PM
Yes, the Canadian Pontiacs had a 261 and they were a great motor. More than that, because they are so popular, there are many new upgrade goodies available.
I think JD was wondering about how the mounts would work out, right ?
1951 1 Ton Completed
#38875 11/01/2003 3:09 PM
truckernix..On my 53 chevy truck there is one
mount at the front and one under the rear (I guess you say under the transmission)..I want to replace the motor in my 46 chevy truck and I was
told any motor from 47-62 (235) would bolt right in. But this pontiac motor looks different the
motor mounts are located on each side..What kind
of probablem will I have to put this in my 46
1937 ford coupe
#38876 11/02/2003 4:28 AM
ape Offline
hay jdhoward, I was told any stovebolt 6 would mount into my 40' half ton. I got a 62' 261. It did(except for the "fan"thing. jim
#38877 11/02/2003 11:18 PM
JD,
someone on here will give you the details but, there is virtually no mounting difference that I know of between the 235 and the 261.
#38878 11/03/2003 2:54 AM
I have a USA spec '62 261. It fits in place of the 216 but I ended up using an electric fan because I did not want to fight clearance issues. The fan sits low on the block instead of up high like pre-'55 motors. I shortened the water pump and used a FOMOCO pulley that bolted right on. That has plenty of clearance to the radiator now, but the stock fan was sitting below the bottom half of the radiator so I run a 2000 cfm electric pusher fan with a thermostatic switch and it works great.
The only other two problems I ran into were the oil filter lines and the belcrank for the throttle linkage. The stock USA 261 has a full flow oil filter mounted to the rear part of the intake manifold, and it hits the steering linkage. I moved mine to mount to the front of the intake and got new oil filter lines (1/2" NPT). This takes the big cannister filter like the early V8s do, not the beehive type. All the oil flows through it.
The throttle linkage requires some bending and shortening of the stock pedal rod. After some trial and error I made it work perfectly. I made a new rod from the bell crank to the carb with some threaded rod and ball joint ends from the hardware store. The ball joint ends are just like miniature tie rod ends and are the best thing since sliced bread. They make the action smooth and tight.
Oh, and if you want to use the bourdon tube temperature gauge, you need a brass adaptor for some heads. Mine needed it. A 1/2" NPT male to 3/8" gas flare female did the trick.
