7 members (Mike in Sycamore, Leo, Gdads51, 1955 1 Series, Bill Trotter, cmayna, ShopRag), 109 guests, and 1 robot.
Topics128,113
Posts1,056,280
Members48,439
#38853 01/01/2005 1:33 AM
Junior Member
Junior Member
It doesn't really make sense to me why you're supposed to set timing at idle by maximizing the vacuum reading with the hose to the distributor disconnected. As soon as I hook the distributor back up the timing is changed-advanced. I'm trying to sort out some other bugs but this has me wondering. enlightenment? thanks
#38854 01/01/2005 4:00 PM
Riding in the Passing Lane
The timing is set for basic timing. The advance
systems are enginered for certain driveing
conditions for more power & economy. The vacuum
advance is for light throttle economy & goes off
under heavy or full throttle to prevent pinging.
The centrifical advance is inside the dist. &
increases with RPM. smile
1972 Chevy c10 Cheyenne Super
#38855 01/02/2005 7:00 AM
Sounds like your vacuum advance line is connected to full manifold vacuum. If it were connected to a ported vacuum it wouldn't make much difference at idle whether you disconnected the line or not, at least in my experience. However, even with ported vacuum, when messing with timing I still disconnect the vacuum advance just to be sure. A ported vacuum source will be above the throttle blades therefore at idle will have barely any vacuum. Many older carbs have full manifold vacuum. Seems more carbs were built with ported vacuum as a result of the Clean Air Act in the 60's.
With full manifold vacuum, if you didn't disconnect line, your engine would probably crap out before you got anywhere close to what the book says your timing should be. So, you set your timing with vacuum line off and plugged, then when it's set, you re-connect and yes, it will advance because you have full manifold vacuum. The timing will also increase even more (to a point) as you increase throttle. Does this make sense? Sometimes I get longwinded whereas other people can make the same point/statement in 3 sentences.
I dealt with this same issue earlier this year, er, last year when I changed my intake and was experimenting with different carbs.
-David
Kustoms-and-Sleds
Tradin' up dimes for nickels...
My \'65 Chevy C-20
