3 members (Bill Marlow, 2 invisible), 109 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#3885 12/04/2003 2:55 PM
Junior Member
Junior Member
1 Offline
I am building a 1953 3100 I want to update the front end to IFS. I am thinking about using a Heidt, but not sure what the ride height will look like. Does anybody have any pictures they would share with a Heidt Mustang II installed. Maby sombody knows of a better setup. I do not want to slam the front end. Email stexasboy @Yahoo.com
Thanks Scott
Scott
#3886 12/04/2003 5:01 PM
Scott--
Welcome to the Stovebolt! You've come to a friendly spot with lots of expertise.
Going to IFS CAN change your ride's front end, but the final look is up to you. You're right that most IFS set-ups, whether bolt-on or grafted clips, will bring the front end down. The stock '47-54's use the straight axle and ride high with a feel for every bump. The conversion to IFS brings a lower profile, but you can offset that change with block, spindle and spring combinations that approach a stock profile.
I regret I don't have any photos of my own to share, but hope others will pitch in. Welcome!
#3887 12/04/2003 5:26 PM
D8 Offline
Brother used a heidts crossmember kit and it was not too low with stock type spindles . The 2 inch drop spindles are what you see in most pictures . I dont know how to post pictures yet but i will see if we can . The little bit lower ride height is a little safer i would think .
#3888 12/04/2003 7:54 PM
D8-
A recent thread walked folks through posting an image on the Stovebolt.
Visit: 38 Chevy Thread
We lika da pictures! eek
#3889 12/04/2003 11:03 PM
I would go with one of those nifty dropped axle fron Cenpen: less expensive, very traditionnal.
cenpen.com
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
#3890 12/05/2003 6:07 AM
Here's a picture of my truck with the Mustang II suspension. I have to add that I have air ride and the front end would normally be about 2 inches higher.....if that makes a difference smile
[img]http://www.50chevy.freeservers.com/right%20side%20truck.JPG[/img]
Joe
#3892 12/15/2003 1:12 AM
Chevy1- Is that with 2" dropped spindles or stock height spindles?
#3893 12/15/2003 4:07 AM
Tucker,
I am running stock spindles with the Heidts 11-inch disc brake conversion kit and Fat Fendered Street Rods Front and Rear Swaybars.
Joe
