7 members (55shaker, frogfarmer, Opelika Tom, Gray_Ghost, Hanks custodian, cmayna, TGP),
111
Mod | | | Forums66 Topics128,185 Posts1,057,203 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38829 11/24/2004 10:52 PM | Joined: Feb 2000 Posts: 11 Apprentice | | Apprentice Joined: Feb 2000 Posts: 11 | I have a 1951 3/4 ton GMC that originally came with a 228 cid engine. Would this truck accomodate a 1951 270 cid GMC inline six engine? Would the motor mounts be the same? would it mate up with the same transmission? | | |
#38830 11/24/2004 11:09 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I believe the motors are externally identical. My '55 1st had a 248 from the factory, but now has a later 270. It looks like it grew there.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#38831 11/25/2004 2:57 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | GMC stuff is all same-o-same-o outside but the flywheel is different 228/248 don't interchange with 270/302
You may have to change the starter ring gear depending on which combo you use....but not rocket science....just look and measure carefully | | |
