5 members (BC59, JoergK., Otto Skorzeny, Cosmo, 1 invisible), 60 guests, and 5 robots.
Topics128,181
Posts1,057,172
Members48,465
#38829 11/24/2004 10:52 PM
Apprentice
Apprentice
I have a 1951 3/4 ton GMC that originally came with a 228 cid engine. Would this truck accomodate a 1951 270 cid GMC inline six engine? Would the motor mounts be the same? would it mate up with the same transmission?
I believe the motors are externally identical. My '55 1st had a 248 from the factory, but now has a later 270. It looks like it grew there.
GMC stuff is all same-o-same-o outside but the flywheel is different 228/248 don't interchange with 270/302
You may have to change the starter ring gear depending on which combo you use....but not rocket science....just look and measure carefully
