5 members (Otto Skorzeny, RLB, TUTS 59, NJC, 1 invisible), 88 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#38800 05/16/2005 7:20 PM
Junior Member
Junior Member
I was going to swap my 3/4 ton gears from stock 4.57:1 to 3.90 or 3.83 or something like that. I'll obviously need to change the front gears as well. Can you give me ring & pinion numbers to help me with this front & rear change?
Squeeg
#38801 05/16/2005 9:19 PM
I'm not familiar with the axles they put under the K20's, but if they are the Eaton axles you aren't going to have many choices for gears. The good news is that GM used these axles for a long time, but the only factory gearing I am aware of is 4.56 and 4.10 and maybe a 5.14 or something along those lines. There is/was an aftermarket 3.90 set available that depending on the year of the third member is either a bolt-in or needs some minor modification. There are previous threads about this on this site, and I know there are a few on here that have swapped and used the aftermarket gears, so maybe they will chime in.
I also believe that Dana axles were an option on certain trucks from this era. I've never seen one myself, but if you have one of these, it seems like it might be easier to get different gears.
Aaron
