| | | Forums66 Topics128,031 Posts1,055,436 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38800 05/16/2005 7:20 PM | Joined: May 2005 Posts: 2 Junior Member | | Junior Member Joined: May 2005 Posts: 2 | I was going to swap my 3/4 ton gears from stock 4.57:1 to 3.90 or 3.83 or something like that. I'll obviously need to change the front gears as well. Can you give me ring & pinion numbers to help me with this front & rear change?
Squeeg
#38801 05/16/2005 9:19 PM | Joined: Sep 2000 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 67 | I'm not familiar with the axles they put under the K20's, but if they are the Eaton axles you aren't going to have many choices for gears. The good news is that GM used these axles for a long time, but the only factory gearing I am aware of is 4.56 and 4.10 and maybe a 5.14 or something along those lines. There is/was an aftermarket 3.90 set available that depending on the year of the third member is either a bolt-in or needs some minor modification. There are previous threads about this on this site, and I know there are a few on here that have swapped and used the aftermarket gears, so maybe they will chime in.
I also believe that Dana axles were an option on certain trucks from this era. I've never seen one myself, but if you have one of these, it seems like it might be easier to get different gears.
Aaron | | |
