6 members (66flea, moparguy, ronsway, TUTS 59, 1955 1 Series, 1 invisible), 347 guests, and 4 robots.
Topics128,154
Posts1,057,015
Members48,460
my engine kit came with the old rope seal and the neoprene what do you guys use
I prefer the neoprene seals. Fred
If doing a full rebuild this looks like a good way to go:
http://www.webrodder.com/article.php?AID=406&SID=32
You Tube
If the seal area on the crank has not been turned or not rust pitted the neoprene is my preference. Also the neoprene seal does not work well in engines with shims on the mains.
My Blog
I used neoprene on my 235. When you install it try to offset the half where it joins the other. This is hard to describe in writing but basically I had one end of the top half recessed in the groove and the other end sticking out. The same in the main cap. What this does is offsets the seam so it does not line up with the mating surfaces of the cap/block. This will prevent further leaks.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
That's exactly what my Father and I did when rebuilding the engine a few years ago.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
