6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#3871 01/30/2004 2:11 AM
Junior Member
Junior Member
Here's a question: Has anyone or would anyone use a "gear splitter" in their 1/2 ton truck? A friend just gave me a 1985 SM465 transmission from a 1 ton truck he once had and will give me the gear splitter, stick, etc. soon. This unit sits between the bell housing and the transmission. I know the SM 465 will fit behind my L6 with some machining of the bell housing and bearing retainer, but I will probably use the original SM 420 that came installed as the splitter will fit it too. I have already rebuilt my rear end including new 3:38 gears. Is this worth doing? I thought it might be kinda cool. I still have a Saginaw 4 spd on the back burner too.
#3872 01/30/2004 5:16 PM
Haven't put a second tranny on a 1/2 ton, but I have driven a lot of bigger trucks with them.
First, how far will this move the 4 speed aft? Your gearshift will move back with it, might require bending to clear the seat. With 3.38 gears, and an o.d., your highway rpm will be pretty low. I don't know what engine you have, but you will be below the power band of most sixes. I would first build without the splitter, and see if I liked it.
Fred
52 3600
69 C-10
