1 members (baldeagle),
100
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 24 Apprentice | | Apprentice Joined: Sep 2007 Posts: 24 | What's the best way to wrap a bundle of wires under the hood so they look neat? 53 chevy pickup | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Scotch Super 88 electricians tape..or BLACK split wire loom..those are my 'druthers'.
Wires nicely and carefully wrapped with the electricians tape tend to look more factory than the loom. If you forget a wire or need to add one later, the loom fits the bill.
Stuart | | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | Hi Bob... I'm a new guy here so I might be breaking new ground and paradigm. But there could be many answers to your question, depending on weatehr you're doing a authentic restoration, going for a ultra clean look or just tidying up. But in general you can buy all sorts of solutions. I recommend McMaster Carr for some good stuff www.mcmaster.com/ they have almost all of those special bits and pieces to real nice job. Check the online catalougue page 788 for a start. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When I made up my harnesses, I used a product called Spiral Wrap, made by Micro Plastics Inc. It is a pliable wrap that fits a bundle from5/16" to 3" in diameter. I found that it was great to work with and made for very nice transitions in bundle size. I did the whole truck with it. | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | if you know you are done w/ your wiring you can use the shrink wrap tubing. most auto shops and suppliers, as well as some of the larger home wharehouse places carry it and it comes in all kinds of lengths and diam size for diif size bundles
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
