5 members (gswbbc, Eisenholtz, 50Chevy3100, Bill Hanlon, 3800GUY), 101 guests, and 1 robot.
Topics128,041
Posts1,055,479
Members48,424
#383045 03/04/2008 12:17 AM
Apprentice
Apprentice
What's the best way to wrap a bundle of wires under the hood so they look neat? 53 chevy pickup
bobshollow #383049 03/04/2008 12:22 AM
Scotch Super 88 electricians tape..or BLACK split wire loom..those are my 'druthers'.
Wires nicely and carefully wrapped with the electricians tape tend to look more factory than the loom. If you forget a wire or need to add one later, the loom fits the bill.
Stuart
bobshollow #383054 03/04/2008 12:32 AM
Hi Bob...
I'm a new guy here so I might be breaking new ground and paradigm. But there could be many answers to your question, depending on weatehr you're doing a authentic restoration, going for a ultra clean look or just tidying up.
But in general you can buy all sorts of solutions. I recommend McMaster Carr for some good stuff www.mcmaster.com/ they have almost all of those special bits and pieces to real nice job. Check the online catalougue page 788 for a start.
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
The Ned #383206 03/04/2008 4:33 AM
I use this vinyl wire wrap from Eastwood. It has no adhesive to get sticky and attract dust. Same stuff that comes on many factory wiring harnesses.
http://eastwood.resultspage.com/sea...wire+wrap&submit.x=34&submit.y=8
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Fla54Chevy3100 #386487 03/11/2008 3:02 AM
When I made up my harnesses, I used a product called Spiral Wrap, made by Micro Plastics Inc. It is a pliable wrap that fits a bundle from5/16" to 3" in diameter. I found that it was great to work with and made for very nice transitions in bundle size. I did the whole truck with it.
1951 1 Ton Completed
truckernix #387397 03/13/2008 2:57 AM
if you know you are done w/ your wiring you can use the shrink wrap tubing. most auto shops and suppliers, as well as some of the larger home wharehouse places carry it and it comes in all kinds of lengths and diam size for diif size bundles
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
