3 members (cmayna, TUTS 59, 1 invisible),
146
Mod | | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | I am working on my 65 SWB and I am trying to remove the bushings from the trailing arms. How the heck do you get those things out? I have ordered new bushings with the new casings but I can't seem to get the old ones out. Any help wwill be much appreciated. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Burn the rubber to remove the inner part. Then you can remove the outer shell with a torch if you are good & careful. If not a muffler cutter or chisel. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I had to burn the rubber out on a 1966,like wrenchbender described. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jul 2006 Posts: 40 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 40 | Heat the outside trailing around the bushing until it's starting to turn red. do this on both sides and the rubber - being on fire will fall out. Then take an 1-1/8 socket,which is the size of the bushing, and give it a smack with a hammer and it will come out.Please wear leather gloves to do this as I,m talking from experience, but it works great. | | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | Thanks guys, I'll give it a try. | | | | | Joined: Apr 2010 Posts: 2 Moderated | | Moderated Joined: Apr 2010 Posts: 2 | Where did you locate the bushing shells, or I believe you called them casings. I destroyed the ones on my 65 C10 before I knew that you should save them. | | |
