4 members (Oswald, treegrower, Nick in Manitou, 1 invisible), 40 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
#386358 03/10/2008 10:13 PM
V
Apprentice
Apprentice
V Offline
I am working on my 65 SWB and I am trying to remove the bushings from the trailing arms. How the heck do you get those things out? I have ordered new bushings with the new casings but I can't seem to get the old ones out. Any help wwill be much appreciated.
Riding in the Passing Lane
Burn the rubber to remove the inner part. Then you can remove the outer shell with a torch if you are good & careful. If not a muffler cutter or chisel.
1972 Chevy c10 Cheyenne Super
I had to burn the rubber out on a 1966,like wrenchbender described.
1951 3100 Chevrolet
Heat the outside trailing around the bushing until it's starting to turn red. do this on both sides and the rubber - being on fire will fall out. Then take an 1-1/8 socket,which is the size of the bushing, and give it a smack with a hammer and it will come out.Please wear leather gloves to do this as I,m talking from experience, but it works great.
V
Apprentice
Apprentice
V Offline
Thanks guys, I'll give it a try.
Moderated
Moderated
Where did you locate the bushing shells, or I believe you called them casings. I destroyed the ones on my 65 C10 before I knew that you should save them.
