0 members (), 41 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#385934 03/09/2008 8:10 PM
my mustang II kit from TCI came with two spacers in the kit for the rack mounting. are theese needed? it looks like it would space the rack out almost half an inch.
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
Mark:
When you have parts that you think are an option to use you better check with the vendor before not using them. Call TCI and see what they say.
~Jim
you have to use them so the nut for the lower control arm bolt will clear the rack. I found out by putting all the pieces together and checking.
Always a reason...
~Jim
When I installed mine I bought it thru a local dealer who had installed several of them in his shop.So I was fortunate to have good info available. Yes you want to use the spacers,and if you have any questions call or Email TCI and they will help you out.I had one problem with the power steering setup,and got in touch with TCI,they were glad to help me out.
I used the spacers also. Called TCI for the info, very helpful!!
