| | | Forums66 Topics128,078 Posts1,056,024 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | my mustang II kit from TCI came with two spacers in the kit for the rack mounting. are theese needed? it looks like it would space the rack out almost half an inch. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Mark: When you have parts that you think are an option to use you better check with the vendor before not using them. Call TCI and see what they say.
~Jim
| | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | you have to use them so the nut for the lower control arm bolt will clear the rack. I found out by putting all the pieces together and checking. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | When I installed mine I bought it thru a local dealer who had installed several of them in his shop.So I was fortunate to have good info available. Yes you want to use the spacers,and if you have any questions call or Email TCI and they will help you out.I had one problem with the power steering setup,and got in touch with TCI,they were glad to help me out. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I used the spacers also. Called TCI for the info, very helpful!! | | |
