1 members (klhansen), 98 guests, and 0 robots.
Topics128,126
Posts1,056,356
Members48,441
Apprentice
Apprentice
I am installing a LDA Prefix 235 enigne into my 51 3100 which is painted Olive Green.
1. Anyone have a Part # for the High temp colors below in a spray can?
What color should a 51 chevy engine be for stock?
Olive:
Gray:
2. Anyone have bolt dimensions for the front two mount bolts and the rear two corner trans mount bolts? (Thru frame/mount to engine)
Thanks Guys!!!!!
Welcome to the Bolt, Michael.
Perhaps you already knew that the "L" means your engine is a 1953, in 52' the "D" meant it was in a Series 5000 truck (I don't know about 53') and the "A" signifies a regular engine, I believe, built at the Flint plant.
Your mounting bolt questions can probably be answered by you if you look at the 1929-1957 Chevy Master Parts and Accessories Catalog put online by Keith Hardy.
Look at the index for the site if you get a chance, it is an amazing amount of free information.
Here is a head start for you looking at the catalog.
Engine Mount Illustrations: look thru several pages.
http://chevy.tocmp.com/1929_57chevyparts/57cmpc0128.htm
List of Mounting Bolts and Sizes: Again several pages of info.
http://chevy.tocmp.com/1929_57chevyparts/57cmpc0125.htm
If someone doesn't answer soon, I bet you could "Search" the stovebolt site for
"Engine color" and find some info about your other question.
Hope this helps.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
The grey spray paint is available from Eastwood Co. Don't know about the Olive or what its for. (?)
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I got my Engine Gray paint at Hirsch Automotive but I'm sure "someone" will be by shortly with his scribe to tell you it's the wrong color. eeeek
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
The color would be a very dark gray. Supposedly the Filling Station has the right color. But it is very pricey. Paint it the color you like is my suggestion.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
