4 members (wilbur53, 2-Ton, 2 invisible), 63 guests, and 1 robot.
Topics128,076
Posts1,055,920
Members48,429
#381497 02/29/2008 3:04 AM
hello. when going from standard drum brakes to power disc front brakes, does the booster mount under the truck where the factory master is ? is it a smaller booster or what ?
also, has anyone done just the discs without the poer booster ? if so, is it a lot better than the front drums, or did you wish you would have gone witht he booster also ?
thanks much...
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Ratrodking, check out my website and you might get some ideals i make my own bracket and get a 7" dual diaphram booster with the vette style master on ebay try pirate jacks http://resurrectionvintageautoparts.webs.com/
1949 SUBURBAN
Another question without the year and size of truck. Hard to answer. Is it a 1929 model? Maybe a 1972?
SORRY. 57 CHEVY 3100
~Jim
big chevy 3600, thanks much... and special things to consider when installing ? how do you adjust the porportioning valve correctly ?
thanks again.
The CPP unit has the proportioning valve built in. No sweat.
~Jim
CPP has a bunch of choices you can make, disc/disc(mine), disc/drum, and drum/drum. It has been two years since I bought so my memory is not clear but if you will call them they will explain what you need. When talking to them check on the need for a residual valve for the system that keeps fluid from flowing back to the MC.
http://www.classicperform.com/Store/1947_59_Trucks/4754BBD.htm
~Jim
Ok, the '57 will be like my '56. I didn't use the power booster but here's how I mounted the dual cylinder with the CPP bracket and ran the lines.
thanks guys, very good info. i will now research....
I've got an 8" dual under the floor of mine with a ford master. Need to swap that to a corvette style one day.
Dave
1954 custom 1-ton (1 of a kind)
thanks so much guys for the very helpful info. i will now start a specific thread on power disc drum or maual disc drums.
thanks again so much
