1 members (Hotrod Lincoln),
60
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 26 | Have a question on VIN #'s. My VIN plate was painted over, but you can see the stamped #'s. The title has a different # on it. Should I or can I possibly have the title changed to actually match the one on the VIN on the cab door jam?? The truck has been restored with a crate 350 and 10 bolt rear end, so I don't know if they used a engine or rear diff # for the new VIN. I'm trying to contact the guy who did the resto. The truck is from California and when I decoded the VIN it also shows it was built in Cali. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The # on the title is most likely the serial # from the original engine. As to changing it to the body serial number, sheck with your local DOT. Since it no longer has the engine that the # came from, I don't see where there should be any issue with titleing it with the # on the body.
Bill Burmeister | | |
