7 members (Joe H, DJMTruck, Charles in CA, WICruiser, dt235sd, Donf, 1 invisible),
90
Mod | | | Forums66 Topics128,259 Posts1,058,301 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 23 Apprentice | | Apprentice Joined: Aug 2007 Posts: 23 | I need some help with a rearend for my 54 chevy piciup, its a GM rearend . it measures about 541/4 from backing plate to backing plate There are no bolts to remove the rear cover and it is held in with 10 bolts . I cant find the codes on the axles but there are some markings on the carrier these are raised and were part of the casting . as follows H267 (Means it was made in 1957?) also Gm25 and 3725899. Stamped into the casting is AC101 I got this for free to use in my old 54 chevy pickup , its the right width and I am going to run a 6 cylinder so it wont be getting a beating but I need to redo the brakes, would help to know what it came from . Thanks very much | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | If it takes a five hole wheel sounds like it might be a 55 to 64 car rear end. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | From the stamped numbers, it appears to be a 4.11 rear from a late '57 or early '58 passenger car. Waht kind of suspension mounts does it have? Leaf spring or 3 link coil spring?
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 23 Apprentice | | Apprentice Joined: Aug 2007 Posts: 23 | It has cups for coil springs and yes it is a 5 lug
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That pegs it as a '58, but with the gearing, there won't be much gain over the stock diff other than getting an open driveline, which will require a different trans, too.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 23 Apprentice | | Apprentice Joined: Aug 2007 Posts: 23 | Thanks for the help , I already have the OD trans for it . | | |
