0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38441 04/17/2004 5:30 PM | Joined: Jan 2002 Posts: 20 Junior Member | | Junior Member Joined: Jan 2002 Posts: 20 | what's holding this thing on the bottom and how do I remove it?
It's a bit hard to see what's down there, since this is my Grandpa's 62 and it's covered in Chicken Chit :-) But, it feels like there are either 2 broken bolts or the bolts come from the other side (which seems to be inside the pan?)
62 1/2 Ton Stepside, 3 on the tree and 235 I6 Grandpa gave it to me, it is straight and original with about 90K original miles..
#38442 04/17/2004 7:29 PM | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Removal of oil pan is required to access 2 bolts holding on timing cover. | | |
#38443 04/17/2004 7:42 PM | Joined: Jan 2002 Posts: 20 Junior Member | | Junior Member Joined: Jan 2002 Posts: 20 | Not what I wanted to hear :-(
I think this thing may have slipped a tooth on the timing gear. I had it running pretty good, then I killed it one day at a stop sign when engaging the clutch. It never ran right since. I know it's getting fuel and fire (massive backfires), and I've tried every tooth on the ditributor gear. I think it's down to the timing gear, whaddaya think?
#38444 04/18/2004 4:20 AM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | It's the timing gear. Pull the oil pan to get to the two bolts holding on the cover.
Some one else will chime in and tell you how to convert the bolt holes, so you won't have to pull the oil pan the next time you need to pull the timing cover. | | |
#38445 04/18/2004 10:00 PM | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | Once pulled apart it's obvious. Drill out threads on timing chain cover and tap to the next size larger bolt in the cap to receive the bolts from the outside in, won't have to pull the pan if there is a next time. Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
