| | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | Is there any difference in the 1/2 to 3/4 ton 47-54 truck? To my knowledge the frames are the same from the cab forward, the differences start after the rear cab mounts. The reason I ask is because am considering using the Chassis engineering MII kit, they say the kit fits 1/2 ton only, mine is a 3/4 truck. I contacted CE a few weeks ago and yet to hear back from them as to why they say 1/2 only, or is there something am totally missing? Thanks...Eric | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | I believe the frames are different between the 1/2 and 3/4 tons. THe 54 1/2 ton frames are different from the 47-53 1/2 ton frames. Samantha | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The frames are different. I believe the channel is taller and deeper and the metal is thicker on the 3/4-ton than the 1/2-ton. I can't tell you how much that close to the front, where it could make a difference in mounting the kit.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The major difference between the 3600 and the 3100 series is the back half. The rear rails are 11 inches wider in the 3100. Other than being a bit heaver steel (I've been told) the rest of the frames are alike. There should not be any difference that would affect an MII installation. My IFS was not a problem and I wouldn't think yours would be either. http://good-times.webshots.com/photo/2838852770099708909cIMZol
~Jim
