0 members (), 150 guests, and 0 robots.
Topics128,101
Posts1,056,180
Members48,436
#382524 03/02/2008 9:29 PM
Hi gang!
Well, I have finally given up on ever finding a carb (other than Rochesters) for my 261 so am now at the point of thinking about picking up a complete engine (with carb) and dropping it in. Will a 292 or 283 match up to my bell housing and motor mounts? (It's a 1962 C-30) Or do I have to go with a 216 or 235?
David
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
U
U Offline
If you haven't given up on your 261, have you looked at the manifolds and the carbs available at The Stovebolt Engine company?
Dual Holley-Weber & Carter-Weber carbs seem to work fine for many people. I'm putting up with dual Rochesters but may switch to Carter-Webers.
I agree with tclederman. I think a Holley-Weber or Carter-Weber will save you a lot of work money and trouble. I've looked at replacing my 235 with a 292, and the offset motor mount scares me a little. A V-8 is going to make things pretty tight under the hood, and the tweaks won't be free. Motor mounts for a V-8 are going to run at least $50 and I've heard that someone has a complete ??-Weber kit for less than $100, with linkage and manifold water heater.
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
was considering the same set up in my 46 1/2t. just saw on the stovebolt engine company site the bolt in engine mount kit for $120. that should make things a little easier.
http://www.stoveboltengineco.com/acartpro/product.asp?productid=138
however, there seems a need for quite a bit of consideration when going to the 292 for bellhousing, clutch, tranny and so on. see my thread in here 261 vs 292 lots of things to think about
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
I went with the Holley/Weber setup on my 56-235 engine....couldn't ask for a more trouble-free fantastic performing carb. Eliminated all the inherent issues commonly found in a Rochester. Have pictures of the install and linkage setup in my Webshots album.
After initially suffering from all the leaking, fumes,hard starts, poor idle, hesitation and rich conditions from a heavily worn Rochester, the Holley/Weber was the most logical fix. Ditto for the Carter/Webers that I'm running on my 60-235.
Stovebolt Engineering has put together a great combination that will appeal to any driver who wants the most bang for their buck.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Jim & Caroline
Holley/Webber 2 bbl carbs from Langdon's Stovebolt are cheap and work very well. They even cell an adapter to bolt onto the original manifold.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
