| | | Forums66 Topics128,169 Posts1,057,035 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 49 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 49 | What do you recommend as a donor for a gas tank for a 50 AD short 1/2? I want to mount it in the frame and will be running a 650 carb. If a donor tank is out of the question how about new? Thanks in advance,Jeff | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Depends on how you want to install it. I have seen some people use a fuel cell, with the filler door in the bed of the truck.
But another tank that might work pretty slick is one for a 1969 Firebird/Camaro. It's not a real deep tank, but holds 16 or so gallons, and has an extended fuel neck out to the rear that could be positioned so that it's under the tailgate. That's what I'm going to try to use.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jun 2007 Posts: 49 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 49 | OK I will !!!! Having a bad day??? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Check your measurements and start looking for what will fit and suit your purposes. The 80s blazer is used by a lot of AD owners. I had a custom aluminum 20 gal. built. http://good-times.webshots.com/photo/2540282850099708909YZvPCm
~Jim
