0 members (),
58
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Have a chance to buy an 86 firebird tilt steering set up. Builing a 49 chevy pickup cruizer. Wondering if this would work. Anyone tried this set up? | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Vickraft, what do you plan to hook the steering column to? MII, power steering, origninal steering gear? Just about any old steering column can be fabricated to fit in the truck. I put an S-10 tilt in my 53. You just need to figure out where the column will exit the cab, I moved mine over to line up with the Nova rear steer sub-frame. Only needed one joint. Theres lots of information on this site for fabricating the steering column, just do a search. | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Hi Yakimabowtie I have mustang II kit from TCI. Will be installing sometime in May or June. I guess from what you explained, this column is a good candidate. Sounds like if I concentrate on clearance & alignment in as straight a line to the the mustang II power steering rack I should be ok. Does the column have to be Tilt? The reason I asked is because I already have a real nice column from a 91 Astro that is not Tilt? Thanks for your time &consideration.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I would not worry about the steering column now but wait until I had installed the MII then take measurements. You will find it difficult making the shaft a straight line to the MII. I have seen the shaft run through the firewall at about 2 inches below the original hole which allows the shaft to be almost straight to the MII steering box. I am assuming you will replace the 216 with a SBC.
~Jim
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Thanks Big Chevy 3600 for the good advice. This makes good common sense. v6 will follow the Mustang II IFS.
