0 members (),
91
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38394 02/15/2004 10:59 PM | Joined: Feb 2004 Posts: 11 Junior Member | | Junior Member Joined: Feb 2004 Posts: 11 | Why would the timing marks be out by close to 120 degrees on my '68 250 cu in? The ignition and valve timing is good, but I had to make a new mark on the balancer. I understand the inner and outter parts of the balancer can move, but I wouldn't expect this much. | | |
#38395 02/16/2004 12:47 AM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Fred,
Once the bond is broken between the outer ring and the rubber that is between the inner and outer parts, it's only a matter of time until the outer ring will move forward or backward and make contact with something. There's a place in Redding/Anderson, CA called Damper Dudes that rebuilds them.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
