7 members (hdgeren, NJC, Wickedbass, Gone, Otto Skorzeny, rfs56trk, Peggy M), 53 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#38394 02/15/2004 10:59 PM
Junior Member
Junior Member
Why would the timing marks be out by close to 120 degrees on my '68 250 cu in? The ignition and valve timing is good, but I had to make a new mark on the balancer. I understand the inner and outter parts of the balancer can move, but I wouldn't expect this much.
#38395 02/16/2004 12:47 AM
Fred,
Once the bond is broken between the outer ring and the rubber that is between the inner and outer parts, it's only a matter of time until the outer ring will move forward or backward and make contact with something. There's a place in Redding/Anderson, CA called Damper Dudes that rebuilds them.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
