| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38193 11/02/2003 9:29 PM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Is there any way of repairing the threads on a axle..I guess at one time or another the large nut that goes onto the end of the axle must have went on cross threated and now I have little or almost no threads for the nut to hold on.
1946 chevy 1/2 ton panel 1937 ford coupe | | |
#38194 11/03/2003 1:28 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | IF you have that done, make sure it is done by a qualified welding machine shop. I would replace the spindle if it were my truck. - Not worth risking your life over
#38195 11/03/2003 4:16 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If it's actually a threaded axle it's on a full floater, 3/4 ton & up. Whether it's that or a front spindle, it's easier to replace than to rethread. On a spindle, you're trying to weld high strength steel, which will have to be heat treated. If it's a rear axle housing, you'll have to go to a specialist, welding the cast steel will be easy, finding someone with the tools to rethread will be tough.
Fred 52 3600 69 C-10
