8 members (walter74, moparguy, TUTS 59, Wickedbass, 50Chevy3100, FAST55, Wally / Montana, Mike Burns),
91
Mod | | | Forums66 Topics128,065 Posts1,055,870 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38180 07/04/2004 3:33 PM | Joined: Jul 2004 Posts: 16 Junior Member | | Junior Member Joined: Jul 2004 Posts: 16 | We just purchased a 1955 3100, 1st series. There is no motor, but she used to have a 6 cylinder, the 4-speed  tranny is setting in the bed. The truck is in great shape overall. We would like to get some suggestions on where to go from here. Should I find a good six and install that, or should we upgrade to a V8. We are leaning on finding a good six and tranny combo already to go and then install that. Any help would be appreciated. Kevin & Cindy
Kevin & Cindy
#38181 07/04/2004 3:44 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | It depends on what you are going to do with the truck on a daily basis and how fast you need to travel. If you are just trying to have a nice daily driver for around town, I would simply put another 235 straight 6 back in. You could possibly attach the 4 speed tranny you already have and away you go. Keep in mind, the faster you want to go, the better the brakes need to be.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#38182 07/04/2004 4:17 PM | Joined: Feb 2004 Posts: 29,776 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,776 | I'd suggest going with the 6-cylinder, but upgrading to a 250, or maybe a 292 if you can find one. There's nothing wrong with the original 235, but the later-model engine will be a little more reliable, and parts are more available. The 292 will require some motor mount modifications, and a diferent bellhousing and clutch linkage setup, but it will be an easier swap than a V-8. Ditto on the brake upgrade along the way! There are several options, but a disc brake front/drum brake rear setup with a dual-line master cylinder with a power booster will bring the brakes up to modern standards. Jerry
#38183 07/04/2004 5:31 PM | Joined: Mar 2004 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 96 | Check in the Seguin area, I have heard of a JUNK,not salvage, yard over there that has a lot of old vehicles sitting out there. I want to say that the man's name is Don...not sure, will have to check and see if I can find out the name. But I would suggest looking there for a good motor to pull and rebuild. I would tend to agree with putting in a 235 or larger motor. I am in the process of rebuilding a 261 which is just a little stronger than the 235 and is a straight drop-in as opposed to having to make the minor modifications of putting in a 292. Good luck.
Whad you do?!?
Shane 1953 Chevrolet 3600
#38184 07/04/2004 9:45 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There are some good 235 engines in the swap meet section. A lot of good engines are pulled for v8 conversions. It,s a lot cheaper to use one of these than trying to rebuild one & usually better results. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#38185 07/05/2004 12:11 AM | Joined: Jul 2004 Posts: 16 Junior Member | | Junior Member Joined: Jul 2004 Posts: 16 | I think everyone is right about the six, we just want a weekend driver that is reliable and fun to drive. I will work on the brakes, thats a good point. I checked out the yard in Seguin, they have more old cars and trucks than I have ever seen. They are a bit expensive though. I went to get a fender for my 63 Chevy II and he wanted $300.00. I thought that was excessive. But if anyone needs a part, let me know, they have everything you can imagine. Does anyone live near Texas that has a good motor and Tranny?
Kevin & Cindy
#38186 07/05/2004 12:41 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | To bad you are so far away, I have and know of nearly every engine mentioned so far. I have a '54 235 and a '66 292. Just met a guy about 20 miles from me with GMC inlines and V-6's. But that would be quite a long haul just for an old engine. There's going to be some in your area with what you want. I wouldn't go to a yard, they know what they got and price it accordingly. Look for a '54 to '66ish 3/4 ton truck or bigger parked in a private owners property, ask if it's for sale and start dealing. Usually you get the whole truck for the price of the part you want. I recently bought a rust free '54 1 1/2 ton Chevy that runs for a $150.00 and it ended up running pretty well. Good luck, Scott | | |
