3 members (JW51, Otto Skorzeny, 1 invisible), 112 guests, and 4 robots.
Topics128,269
Posts1,058,402
Members48,485
#348140 12/13/2007 4:26 AM
I have a '66 Fleetside and am wondering how the speaker and radio are attached under the dash. Since there is neither on mine, it looks like there should be some brackets for this.
I also don't see any holes up under there for this. I assume the speaker goes up under that grille, but how?
Do I need some bracket for this? I have a new speaker but do not see how this little bracket goes up there.
thanks for the help
sovagary
GS
There is some kind of mounting bracket. You probably will find the necessary hardware for the radio and speaker if you can find a 1964-1966 Chevrolet Pick-up with a radio in a salvage yard
Sovagary, I got a radio from Custom Audio Sound, mine is the USA-3. It had a metal bar that attached to the back of the radio and then I bent it and attached it to an existing hole in the dash with a pan-head machine screw. The knob shafts are threaded and you have a nut, then a washer on one side of the dash, and then another washer and another nut on the other side of the dash that holds it quite snugly in place. I opted for the upgrade since it has AM/FM with 12 AM presets and 18 FM presets and the option for more speakers if I so choose.
The stock radio, IIRC, is held in place with the knob bezels and a nut on the back side of the dash.
For the speaker, I have 2 3.5" speakers in a thin board that is the exact same dimensions of the grille in the dash. I put a machine screw in each corner through the grille and put washers and nuts on the other side of the board to just hang it in place. The speaker that was in it was hung in a similar fashion, I doubt that it was the original one.
If you can wait another day or two, I can get some pictures of my set up and post them here. A good person to talk to is 4-5-6 Chevy Trucks, I think all of his trucks are bone stock and have NOS parts in them. You may want to PM him and find out exactly how the original stuff is mounted.
If you turn up the windshield rubber in the center[near the speaker grill] you will see two holes the speaker bracket bolts to that and holds the speaker in place , I have one, BILL
Moderated by  truckernix
