0 members (), 163 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
im getting ready to put my 60 235 back together for my 46 2 ton.
i have opted for the relocation plate i have a new pump with the 3\8 pulley and an alternator with 3\8 pulley. the balancer on the 60 motor is larger than the old 52 motor should i run it anyway
or should i run the 52 hb withe the 5\8 groove and just let the belt run in the bottom of the groove.
I'd look for a balancer from a early 50's Chevy car with a 3/8 pulley .The later model balancer will turn the water pump to fast at highway speeds.
If the 1960 balancer is a truck balancer which is designed for a 1/2" belt, you can use it. By running a 3/8" belt with the truck balancer the belt will run deeper in the groove and in affect will reduce the diameter to very near the correct diameter for your pump.
My Blog
