| | | Forums66 Topics128,076 Posts1,056,008 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | im getting ready to put my 60 235 back together for my 46 2 ton. i have opted for the relocation plate i have a new pump with the 3\8 pulley and an alternator with 3\8 pulley. the balancer on the 60 motor is larger than the old 52 motor should i run it anyway or should i run the 52 hb withe the 5\8 groove and just let the belt run in the bottom of the groove. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I'd look for a balancer from a early 50's Chevy car with a 3/8 pulley .The later model balancer will turn the water pump to fast at highway speeds. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If the 1960 balancer is a truck balancer which is designed for a 1/2" belt, you can use it. By running a 3/8" belt with the truck balancer the belt will run deeper in the groove and in affect will reduce the diameter to very near the correct diameter for your pump.
See the USA in your vintage Chevrolet! My Blog | | |
