2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38099 07/23/2003 8:48 PM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | I have scratched every surface of the motor on my 1946 panel truck..Here they are..
Head 838773...1937-1940
block...next left to the dist..on a flat boss/ 242495...this number is also stamped further down the block near the front of the block.... next right of the dist..on the facing of the block is stamped GM 48 and around the number 48 is a large circle around it. I Give Up...it don't understand it...I believe it is a 216 with the large pushrod cover..the valve cover is held down with two large nuts... If someone can clear the dust for me I would be very thankful...Was this motor purchased from a engine shop?...Whats with the number??
1946 chevy 1/2 ton panel 1937 ford coupe | | |
#38100 07/23/2003 10:25 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | yes it is an odd # . Have you pulled the starter and checked for a # on the block that would have been hidden there? | | |
#38101 07/24/2003 3:02 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If this is a Canadian motor, you will probably not find the number on any lists. The posted lists tend to be US numbers, whaich are different from the canadian ons. | | |
#38102 07/24/2003 1:27 PM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | well I believe both of you are right..this is a canadian truck...and I did take the starter off and I did find some stamping...but again they seem to be weird numbers..I don't know? any Ideas? Here's what I found CONV 3- H 188 Does any of this help...thanks in advance..
#38103 07/24/2003 4:22 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The 188 is most likley a I88,which stands for September 8 1948. US blocks in 48 and 49 also had a 48 with a circle around it like you found ahead of the distributor.
See the USA in your vintage Chevrolet! My Blog | | |
#38104 07/25/2003 2:39 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | JD, you know that GM has a restoration package that they will supply for a charge of about $35. Mine gave me the date of manufacture, information about the exact model number , color and production figures for the year. In addition they provided all the engineering specs that they had for that year. | | |
