8 members (Donf, 57 Drifter, baldeagle, HandyAndy, gswbbc, tclederman, Cosmo, 1 invisible), 122 guests, and 2 robots.
Topics128,040
Posts1,055,478
Members48,424
#38099 07/23/2003 8:48 PM
I have scratched every surface of the motor on
my 1946 panel truck..Here they are..
Head 838773...1937-1940
block...next left to the dist..on a flat boss/
242495...this number is also stamped
further down the block near the front
of the block....
next right of the dist..on the facing
of the block is stamped GM 48 and
around the number 48 is a large
circle around it.
I Give Up...it don't understand it...I believe
it is a 216 with the large pushrod cover..the
valve cover is held down with two large nuts...
If someone can clear the dust for me I would
be very thankful...Was this motor purchased
from a engine shop?...Whats with the number??
1946 chevy 1/2 ton panel
1937 ford coupe
#38100 07/23/2003 10:25 PM
yes it is an odd # . Have you pulled the starter and checked for a # on the block that would have been hidden there?
#38101 07/24/2003 3:02 AM
If this is a Canadian motor, you will probably not find the number on any lists. The posted lists tend to be US numbers, whaich are different from the canadian ons.
1951 1 Ton Completed
#38102 07/24/2003 1:27 PM
well I believe both of you are right..this is a
canadian truck...and I did take the starter off
and I did find some stamping...but again they
seem to be weird numbers..I don't know? any Ideas? Here's what I found CONV 3- H 188
Does any of this help...thanks in advance..
1937 ford coupe
#38103 07/24/2003 4:22 PM
The 188 is most likley a I88,which stands for September 8 1948. US blocks in 48 and 49 also had a 48 with a circle around it like you found ahead of the distributor.
My Blog
#38104 07/25/2003 2:39 AM
JD,
you know that GM has a restoration package that they will supply for a charge of about $35. Mine gave me the date of manufacture, information about the exact model number , color and production figures for the year. In addition they provided all the engineering specs that they had for that year.
