3 members (Danielbolt, bluechev, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | guys, did these trucks have cab lights like dome lights inside there cabs??? did they offer radio in these years??? | | | | | Joined: Jan 2008 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 100 | Not sure about the cab light - my 3/4 ton doesn't have any wiring for this. You could get a radio according to the excellent site @ http://www.brads41-46chevys.com/id25.html
For those who believe, no proof is necessary. For those who don't believe, no proof is possible. 41 Chevy | | | | | Joined: Jan 2001 Posts: 332 Big Bolt Shop Curmudgeon | | Big Bolt Shop Curmudgeon Joined: Jan 2001 Posts: 332 | No cab light to be best of my knowledge, but an under-the-dash bulb spilled light out into the cab below the dash. Not sure if this was really by design or just be happenstance of the dash bulbs and mountings.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy "Ol Blue", or "THE BIG 'UN"
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Now, what would you need a cab light for? There are only about 5 controls in the whole truck, and you can reach both sides without stretching!  Seriously, there's a "hidden" 3-pole switch under the dash in about the middle which turns on a "courtesy light" over the ignition switch when switched one way, or the instrument lights when switched the other. I reckon you could jumper one pole to the other, so that both came on always. . . My firetruck has a search light you can point into the truck - now THAT'S a cab light! -Michael | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | There was an accessory cab light offered for the GMCs not sure about the chebby. I have never seen a picture, and there is only a part number listed in the accessory catalogue. I believe the panel trucks and suburbans came standard with a dome lamp, but I am not sure if it is the same. It also may have been an option for them.
Some other accessories that were available were armrests, visors (interior and exterior), right side windshield wiper, right side tail light, and right side rear view mirror.
Seatbelts were not an option or factory accessory, and as far as I could tell, neither was an interior rear view mirror. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | My ’41 Chevy has a light right behind the dash between the choke and throttle. This light puts some light into the cab and is controlled by a 3 way switch mounted under the dash. The switch allows you to have all of the dash lights off, or the ones that illuminate the instruments on, or the one near the choke / throttle on. The owner’s manual explains this on page 9 | | | | | Joined: Feb 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 42 | Kip can you send me a pic of that light switch or explain where under the dash. | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Chevy did offer an accessory 6v radio for the 41 and 42-46 trucks. They were installed under the dash to the left of the steering column. 41 had a shiny pot metal face and used tuning knobs...42-46 had a brown bakelite face and had vertical turning thumb-knob controls. They regularly come up on ebay. Take a look at ebay item#140209954109 ...it's that 3 pole courtesy light switch mentioned above...in my experience these switches are rather fragile, they are difficult to find and no accurate repos are available.
| | | | | Joined: Jan 2008 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 100 | Kip can you send me a pic of that light switch or explain where under the dash. Have a look at http://chevy.tocmp.com/chevyowner/42tom07.htmCheers
For those who believe, no proof is necessary. For those who don't believe, no proof is possible. 41 Chevy | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Kip, the accessory light I was referring to is in addition to the dash/ map light, which was standard. From what I can tell it was a dome lamp mounted in the headliner, or above the rear glass. Not sure as I have never seen one or the installation instructions. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Bigbad......
I understand. I can’t remember ever having seen any literature on such a light either. However my trucks PO(s) must have needed a light in that location as there were at least 4 holes up there all in slightly different locations.. | | |
